Sponsored by:
Sponsored by:
Accord 2016 Sport RPM drops below 1000 RPM?
Old 07-22-2016, 10:56 PM
fred123's Avatar
Default Accord 2016 Sport RPM drops below 1000 RPM?
When cruising with the feet off the gas pedal and letting the speed slowly decrease, I could see the RPM meter dropping from 1100 RPM to around 800 RPM when it hits 20 MPH and then back up to 1100 RPM again.
Also when the RPM drops I feel as though the car is halting a bit, as if the brakes have been applied for a split second and then let go.
Is this normal for the car to do? The AC unit has also been turned off.
Old 07-23-2016, 11:39 AM
Prospector's Avatar
Hello, Fred... welcome to the forum
Yes, what you've described is normal
Old 07-24-2016, 07:15 PM
fred123's Avatar
Thank you for the friendly welcome!
It was confirmed at the dealer where I had them test drive the vehicle. Seems like that is normal function of the car to do.
Old 07-25-2016, 06:00 AM
dgp1961's Avatar
Almost A Senior Member
Good for your brakes to as you "learn" to let the car slow itself at lights and stop signs. After awhile you'll probably use it to your advantage and stop braking so much.
Old 07-27-2016, 10:09 PM
fred123's Avatar
Yep, that is exactly what I do. It probably would help extend the life of the brakes too.
Treynelson1
06-15-2020 01:19 PM
crashdummie
05-10-2019 10:37 AM
jamato455
01-02-2014 09:48 AM
kraftwerk
08-22-2011 11:04 AM
Honda Enthusiast
11-26-2010 09:43 AM
Quick Reply: Accord 2016 Sport RPM drops below 1000 RPM?
