Sponsored by:
Sponsored by:
Accord v/6 surging at idle
Old 03-13-2005, 11:56 PM
kwiggers
Default Accord v/6 surging at idle
I have a 2000 2d Accord v6 automatic that sat 3mo in the garage this winter. When I started it up the other day it surges when idling . About every 2 seconds it surges from 1200 to 2000 rps and then repeats it self. I drove it for a couple of days and it didn't go away. Adding new gas when it was low didn't help. Any thoughts on my problem.
kwiggers
Old 03-14-2005, 04:27 PM
Default RE: Accord v/6 surging at idle
Lets start with a loose fuel injector wire harness connector and than move on too a Intake air leak and then off too maybe a bad fuel pump relay...try those 1st and see if that fix's up your problem...Also don't overlook the throttle position sensor, this is also a common problem of your symptoms..
Later Forum Member...
WheelbrokerAng [sm=smokin.gif]
Old 03-16-2005, 07:29 PM
I was going to guess the fuel injectors as well. Happened to my old caddy once. That thing never gets driven either.
Wiley-X
12-12-2011 10:35 PM
amcdonal86
05-08-2011 05:27 PM
Honda hobby
09-15-2009 10:28 AM
wjt
07-02-2007 01:15 PM
wanderer63
11-23-2005 01:17 AM
Quick Reply: Accord v/6 surging at idle
