Sponsored by:
Sponsored by:
Adjusting Valves in 1994 accord ex
Old 01-19-2010, 02:38 PM
miami honda's Avatar
Default Adjusting Valves in 1994 accord ex
Well I adjusted my valves and have a question. I pretty much took took of my valve cover and spark plugs and turned the engine until the valves that i wanted to adjust where pushed up to their highest point. Then I proceeded to gap them according to spec. Now the engine is quieter but I wonder if this method was totally wrong. I noticed that when I turned the power steering pump gear counter clock wise that when the valves reached their peak they stayed there for a few turns before starting to go back down hence my method in adjusting them. Any input would be appreciated thanks.
Old 01-19-2010, 04:06 PM
kris_loehr's Avatar
If you caught the cam at its low point you should be fine. If I am reading your post correctly you verify that you were on the lowest point by finding the area where the cam stays at its lowest point in the profile.
Old 01-19-2010, 04:45 PM
Using the PS pulley to turn the engine, you might have simply seen that the external drive belt slipping.
Minimize that by removing all 4 spark plugs - that way the crankshaft is much easier to move.
There's an arrow on the camshaft sprocket.
pointing to 12:00 oclock = cylinder 1
3:00 = cylinder 3
6:00 = 4
9:00 = 2
In each case the valves for that respective cylinder are not "close" to opening. The engine will turn a ways before they open. Sounds like you were OK.
Measure & adjust with a COLD engine? If the engine was warm, that was wrong.
Old 01-19-2010, 05:34 PM
Yeah I adjusted them with a cold engine and taking the spark plugs as you mentioned made the turning much much easier.
carlsonbru
12-23-2012 10:13 PM
Pattywagon
08-04-2012 01:44 PM
Kerby
06-13-2011 09:22 PM
uAccord
08-26-2008 09:43 AM
blackex19
01-14-2007 02:01 PM
Quick Reply: Adjusting Valves in 1994 accord ex
