AF or O2 symptoms
- I would first check that the electrical connector for the MAF sensor was firmly connected to rule that out as the cause for the CEL coming back after several days.
- If the electrical connector was okay, I would remove the MAF sensor to examine and possibly clean again, let dry, reinstall and see if it changes anything.
- If condition still exist, then like the service manual says, check these parts for vacuum leaks:
- PCV valve
- PCV hose
- EVAP canister purge valve
- Throttle body
- Intake manifold
- Brake booster hose
Even though you haven't got the code checked again from the parts store, can you post a copy of the original Honda invoice? You can block out your personal info.
jrcastro
04-21-2008 10:35 AM
