Air filter change
Old 08-11-2011, 07:12 PM
Deviatorz's Avatar
Default Air filter change
Hi everyone. I was wondering if anyone knows how to change the air filter on a Honda Accord 2007 V6 Hybrid? There's this video on how to change 07 accords here but its for V4's. My engine design is quite different. If you notice, all he had to do was push the cover up and back. I tried doing that with mine it wouldn't detach (the left bottom 2 screws). I fear that there's cables that are attached to the cover (on the bottom, not top) that's preventing me to change it.
Here are some photos:
http://bit.ly/n5otkW
http://db.tt/gt1pQwH
http://db.tt/kiFnQcU
Any ideas on what I should do?
Old 08-11-2011, 08:04 PM
Were you able to remove all four screws?
Old 08-11-2011, 08:10 PM
Tek310's Avatar
your going to want to take off the bolts around the air box, and loosen the hose clamp. the box will lift up and pull out of the hose.
Old 08-12-2011, 06:35 AM
Deviatorz's Avatar
Yes I removed those 4 screws. In the pictures provided I didn't this was after attempting to remove the cover. I might upload another picture of the cover lifted half way.
Bolts as in the four screws? Yea I did removed those. I'm having trouble detaching the left side of the cover. I should've taken a picture. I will very soon. As for the hose clamp, are you sure that is causing the problem? In the youtube video he left hose on and lifted the cover? I'll give it a shot anyways, it couldn't hurt. I'll report back.
Old 08-12-2011, 10:09 AM
MessAround's Avatar
Almost A Senior Member
Are you sure something is holding it down? Doesn't sound right, sounds too complicated. It should just be the four bolts as other people said and just lift.
I find that you don't really need to remove the top cover unless you want to inspect it or the inside of the filter box. Just a quick swap of the filter can be done by pulling the top cover up a bit but not too much. The intake hose usually has a bend that allows you to move it up and bend it out of the way but just don't move it up excessively, you might break it.
If you're afraid of that it would just be better to loosen the hose clamp like Tek said and pull the top cover out of the intake tube, it's easy as pie anyway. Just make sure you remember where the bolt on the clamp is before you start loosening it so you know the proper tightness to tighten it too after you're done. In my case it's usually marked by rust.
Old 08-12-2011, 05:17 PM
Deviatorz's Avatar
I believe the issue is here:
http://db.tt/0P5PDU3
The area where I marked it red, you can see 3 cables bundled together. Beneath those cables is my forth bolt. The teal area I marked shows that all the cables are strapped together by a wiring harness to the side of the cover (no joke). Those cables are stiff so when I tried to lift, the cables prevent me from opening I believe. I can only open half the cover as shown here:
I can't remove the air filter because the opening is not big enough for it to fit through. My mechanic failed to change my air filter as last and, he marked it as passed (I have a feeling I know why...). Now its long over due for a change.
For the intake tube, from my previous photos you can see that its quite short (unlike the V4's). It seems that if I want to remove the intake, I have disconnect everything and fully remove it.
Old 08-12-2011, 06:26 PM
Old 08-13-2011, 06:43 PM
Deviatorz's Avatar
Thanks for the help. I saw the PDF and I think "B" is pointing to the cover for the air filter? I decided to put a tiny bit more force on my cover. Also, I used leverage to remove the air filter (not the housing) and it popped out. I didn't use excessive force, only smart about it to pivot out the air filter. I didn't have to cut the strap on the cable off like the OP did in that post. Here's my air filter:
http://db.tt/1kC2YHa
You might not see if but there's a blob of crap on it (its oily too). Time to pop in my new filter =). This reminds me, I gotta get a cabin air filter as well =/. Thanks for the help.
Special_K
08-12-2011 04:16 PM
accordfan
04-07-2009 07:15 AM
daswede
08-10-2008 12:09 PM
jarede7
05-08-2008 12:54 PM
joe592
07-25-2006 04:01 AM
Quick Reply: Air filter change
