Sponsored by:
Sponsored by:
Alarm on constantly need to disable
Old 10-28-2013, 04:29 PM
horsefly's Avatar
Default Alarm on constantly need to disable
My alarm went off completely draining the battery.
As soon as I connected the charger the horn and lights started up again.
No matter what I try with the key, remote, etc. it continues to go off until
I pull the battery cable off.
How can I disable the alarm system completely. I've searched these posts
but not found any clear instructions. At this point, I just want to disable it.
2003 Honda Accord V6 with all options.
Thanks
Old 10-28-2013, 04:52 PM
On earlier models, you reset alarm and then disable alarm to stop the noise. I haven't had a factory alarm on this model however.
Old 10-28-2013, 04:58 PM
The security alarm system is part of the multiplex integrated control system (MICU). Usually, the alarm going off is due to a faulty hood switch. Disconnect the connector for the switch (located in front of the hood latch) and see if the alarm stops going off.
Old 10-30-2013, 06:58 AM
horsefly's Avatar
Thanks for the replies, however neither suggestion solved the problem.
Guess this means get it to a dealer and pay all the money!! If the MICU has to be replaced that's probably hundreds of dollars. Think I'm ready to go back to a Jeep!
Old 10-30-2013, 08:01 AM
Is the immobilizer recognizing your key? Indicator light should go on for 2 secs when key is turned to On and go off. When key is turned off, the indicator light should flash 5 times indicating system has reset.
Old 10-30-2013, 10:05 AM
When the security system sounds, the B-CAN (Body Controller Area Network) stores the last input (security breach history data) that set off the alarm.
The dealer can use HDS (Honda Diagnostic System) to access the stored history data to help find and fix the problem. To access the last security breach history, they would connect HDS to the OBD-II port and review the history data by accessing the Security Menu.
You may want to make sure your battery is not really weak before you decide to bring in to the dealer for diagnostic. Battery checks are free at most auto parts shops.
Old 10-30-2013, 10:25 AM
You can also try inserting the car key into the driver's door and turn to unlock position to see if it will turn off the alarm.
KD1977
06-27-2013 02:43 AM
gregg0ry
10-17-2009 05:55 PM
ColdPhire
02-20-2008 11:01 PM
lacieday
06-06-2007 05:36 AM
rEEd E.
08-12-2006 04:06 AM
Quick Reply: Alarm on constantly need to disable
