All dash warning lights come on at 1500rpm - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 07-12-2013, 09:29 PM
Default All dash warning lights come on at 1500rpm
Wife car was acting up. When I first had a moment to look at it found that when i would rev up the engine to above 1500rpm, the door/trunk ajar, brake, and SRS, would light up and stay on until it rev drop below 1500rpm. this happen while parked or going down the road. Engine ran fine so let wife drive it home. On her trip the left hand turn signal started to flash fast when she used it, like when you have a light bulb out, but the both lit up. I was thinking ign. sw. so when it finally cool off last night, (13th day of 100 plus degrees), I starting looking around to fine nothing obvious. This morning the battery was completely dead. Charging battery now while disconnected from car, and scratching my head looking around net. Multiplex controler, Alt, Battery, aftermarket stereo, have all came up.
Has any one had this happen? What to look for, Check, Replace Ect..?
Old 07-12-2013, 09:31 PM
Sounds like it may be the alternator.
Old 07-12-2013, 09:32 PM
Thanks for your reply! Why the Alt?
Old 07-12-2013, 09:34 PM
Battery drain overnight. Nothing was on so its a short somewhere.
Old 07-12-2013, 10:26 PM
It may be the alternator. The alternator charges the battery when the car is running. When the rpms goes up, the alternator may not be putting out the proper voltage, which may cause some of those dashboard lights to come on brightly and then fade slowly as the rpms goes down. Did you notice the charging system indicator (battery symbol) on too? In addition, did you notice if the car seem to lose power?
Many auto parts stores can/will test the alternator for free. But, check your battery connections and that the alternator belt is also tight. If you have a voltmeter, you can hook that up to the battery and rev the engine and see if the alternator is putting out the proper voltage.
Old 07-12-2013, 10:51 PM
Well the charge light goes out when started and does not come back on without stopping engine. ? the car just turn 150,000 miles, is this some type of emission notice?
Old 07-12-2013, 10:55 PM
Thanks for your attenion REDBULL-1. Dash light come on bright and stay bright.Will take volt meter out of tool box in the morning and check voltage. Battery still isn't fully charge yet, will have it draw (load) tested tomorrow.
Old 07-13-2013, 04:30 PM
Well it seems to be the Alt. The Voltage output is 36 volts on Autozone Test Equipment.
Old 07-13-2013, 04:33 PM
Strange thing happened. When i pulled the neg. Battery wire from battery to see if engine would die, the wipers came on.
Old 07-13-2013, 05:12 PM
The voltage regulator inside the alternator is bad if it showed an output of 36 volts.
Reply
Thread Thread Starter Forum Replies Last Post
Dash lights come on when driving wheels General Tech Help 2 09-20-2014 05:10 PM
Fuel Warning Light brightens and dims, doesn't just come on Pajamarama General Tech Help 4 08-27-2012 07:12 PM
5th gen accord/Dash and center console lights wont come on.. argarcia86 General Tech Help 2 02-12-2012 07:47 AM
2002 honda accord dash lights come on when full throttle ThatOneAccord General Tech Help 0 08-15-2011 03:01 AM
Come one, Come All Full Exaust Advice nrangerfan Headers, Intake, & Exhaust 7 05-20-2005 02:57 AM
Tags
accord, bright, car, dash, dashboard, dont, engine, honda, lights, on, rev, srs, stops, warning, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
