Welcome to the Honda Accord Forum - Honda Accord Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
I don't know the resistances, so check that manual. But resistance is part of the story. Even if it passes the resistance tests, it might still be bad in the sense that it lets spark leak to ground. You can't test for that with a normal multi-meter.
But with an external coil, you can watch for arcing. You want the engine to be completely cold, and complete darkness. Like 3am after it's been parked all evening & night. Open the hood & turn off all the lights. Start the engine & look for any arcing. A dull blue glow means the spark is leaking out from degraded insulation. Glowing plug wires, replace em. Glowing distributor cap, replace it. Glowing coil, replace it.
__________________
'05 Saab 9²x aero (RIP)
2 '07 Civics
'09 Saab 9³ss
'10 Saab 9³sc
I'm with Jim on this one; seen many coils pass resistance test, yet break down and internally short when under actual electrical load.
So whats the rest of the story, that made you decide to test the coil?
__________________
90 Yota pickup 240k miles "never say die" 22re engine.
92 Acura Legend 115k miles. Wife lets me drive it for oil changes.
The one eyed Mechanic says "The fluid is low"; The two eyed Technician says "WHY is the fluid low?"
Been There, Done That, Read the Book, Seen the Movie, Got the T-shirt http://www.righttorepair.org/
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
