Sponsored by:
Sponsored by:
anyone know the ignition coil specs?
Old 06-21-2010, 12:20 PM
blake's Avatar
Default anyone know the ignition coil specs?
i want to test my ignition coil to see if its good or bad, anyone know what the specs should be on a good coil?
its a 94 accord lx, has the tec external coil
and also, how do i test this coil?
thanks
Old 06-21-2010, 07:56 PM
section/page 23-103 of the manual that can be downloaded from the DIY section describes the procedure.
Old 06-21-2010, 08:04 PM
I don't know the resistances, so check that manual. But resistance is part of the story. Even if it passes the resistance tests, it might still be bad in the sense that it lets spark leak to ground. You can't test for that with a normal multi-meter.
But with an external coil, you can watch for arcing. You want the engine to be completely cold, and complete darkness. Like 3am after it's been parked all evening & night. Open the hood & turn off all the lights. Start the engine & look for any arcing. A dull blue glow means the spark is leaking out from degraded insulation. Glowing plug wires, replace em. Glowing distributor cap, replace it. Glowing coil, replace it.
Old 06-21-2010, 10:38 PM
hondadude's Avatar
I'm with Jim on this one; seen many coils pass resistance test, yet break down and internally short when under actual electrical load.
So whats the rest of the story, that made you decide to test the coil?
Old 06-22-2010, 10:08 AM
blake's Avatar
thanks guys
but my car wont start, i was thinking bad ignition coil but turns out the timing belt skipped a couple teeth
JonJon13926
02-13-2014 10:50 AM
phantomgrey92
10-09-2013 04:45 PM
Robert 1991
03-30-2012 04:13 PM
no_doz
06-11-2006 08:08 PM
Quick Reply: anyone know the ignition coil specs?
