Timing belt advice
Old 10-19-2010, 08:02 PM
Adnoh7's Avatar
Default Timing belt advice
Hello.
I would like to know what parts i need to replace ? My Accord is near 200,000 kilometers (severe conditions - i'm living in Québec) and it's time to change the timing belt (second time).
Do i need to change the Timing Belt Tensioner and the Balance Shaft Tensioner (idler pulley) ? Water pump ? All the seals that come with Timing belt kit ?
Thanks to all.
Accord SE 2000 Automatic
2.3 L
Old 10-19-2010, 08:41 PM
I would definitely change the water pump.
I would only replace the seals that are leaking oil. If there is a balance shaft seal retaining plate available for your car, I would definitely install that. That is probably a dealer only item.
I would guess that the two tension bearings should be ok. I am not sure what severe conditions will do to those bearings at ~125K miles. It certainly won't hurt to change them. They run around $40 each IIRC.
zendao
09-14-2009 12:05 PM
cptskippy
12-23-2008 10:16 AM
Tony1M
04-01-2007 05:42 PM
three
01-27-2007 08:37 PM
woo78f
12-19-2006 06:34 AM
Quick Reply: Timing belt advice
