Sponsored by:
Sponsored by:
where to find listing of bulbs used in 2000 Accord?
Old 11-05-2006, 02:59 AM
tiffany's Avatar
Default where to find listing of bulbs used in 2000 Accord?
I'm looking for a link to a list of bulbs used in the 2000 Honda Accord, do you know of one?
Thank you!
Old 11-05-2006, 05:07 AM
deserthonda's Avatar
Default RE: where to find listing of bulbs used in 2000 Accord?
http://www.drivewire.com/hondaparts/...ccordbulb.html
hope this helps..
Old 11-05-2006, 12:28 PM
tiffany's Avatar
I'm looking for a list that says the location and then the bulb number. For example:
front directional signal 1157
Old 11-05-2006, 05:04 PM
maybe ur looking for this
http://www.sylvania.com/ConsumerProd...de/default.htm
Old 11-06-2006, 03:07 PM
tiffany's Avatar
Yes, that is what I'm looking for. However, I see its missing one of the bulbs I'm looking for. One of the parking lights found underneath the low and high beam. Do you know what the number is for that bulb?
[IMG]local://upfiles/527/1871E658F5214F79BC98AD273924AFE4.jpg[/IMG]
Old 11-06-2006, 03:48 PM
sir_nasty's Avatar
sometimes the easiest thing to do is just pull the bulb out and take it in to the parts store, or look up the number in the parts store book and they should be able to tell you.... I don't know it off the top of my head
Old 11-06-2006, 06:38 PM
in that case no i dont know ,,,,, i didnt think there was one back there... cause if you look at this image you will see only
signal , low and high beam inserts.
http://i17.ebayimg.com/01/i/07/f9/2a/cc_1.JPG
sorry i couldn't be of much help. Good luck
Old 11-06-2006, 06:43 PM
sir_nasty's Avatar
those headlights look like they are aftermarket... if that's the case you may have a bulb in there that isn't stock.... so then you'll have to pull it out and go match it up manually
Old 11-07-2006, 02:13 AM
tiffany's Avatar
The headlights are aftermarket however they are basically the same as the originals - the only difference is that the bottom strip for the parking light is clear instead of amber. The wiring and everything else is the same.
Here's a picture of the back of the original headlights - there you can see the same hole where the parking light bulb goes in.
The bulb is very difficult to get out and therefore, I would prefer to locate and purchase new bulbs before I attempt to pull them out.
The problem is I don't know what kind of bulb it is.
[IMG]local://upfiles/527/1805100A300E4984BD97AAF2A0BA7189.jpg[/IMG]
jbarra515
11-10-2011 12:46 PM
msucurt
07-24-2011 01:26 AM
jbrams
05-11-2010 10:30 AM
stefanb21487
07-18-2007 11:55 PM
GodMachine
05-15-2006 05:09 PM
Quick Reply: where to find listing of bulbs used in 2000 Accord?
