Sponsored by:
Sponsored by:
Accord trouble turning over - "da ta ta ta ta ta vrooom" - 2005
Old 01-13-2013, 08:49 AM
kelcey30's Avatar
Default Accord trouble turning over - "da ta ta ta ta ta vrooom" - 2005
even when my car is hot, starting the engine takes longer than it used to. rather than starting immediately after turning the key, the engine turns but you hear, "da ta ta ta ta ta vroom", it starts.
it's not the battery, and I replaced the spark plugs
Old 01-13-2013, 09:31 AM
Is starter engaging but turning engine over too slowly to start? If yes, the check your battery connections carefully for corroded connections or corroded wires.
If all connections are good, you could have weak solenoid contacts that won't allow enough current flow to enable good starting. Starter replacement is usual fix.
Old 01-13-2013, 12:57 PM
kelcey30's Avatar
Default starter
thanx, Tex. the starter was my next thought as well. the battery is new, and the cables appear clean (except for the goop they sell with the battery) and tight. will look next at starter.
Old 01-13-2013, 01:27 PM
This may or may not be related to your starting problem; but, may be worth a shot. There was a recall regarding faulty fuel pump relays before.
Honda TSB 07-020
Enter your VIN at the Honda America site, to see if your car is part of this recall or if it has already been done.
Honda Automobile Recall Information
Old 01-13-2013, 04:21 PM
kelcey30's Avatar
thanks again. will check
Old 01-15-2013, 01:55 PM
kelcey30's Avatar
Default fuel pump
Honda dealer diagnosed a problem fuel pump. they said it doesn't require immediate fixing, but it will continue to deteriorate. their fix is $600. wow!
Old 01-15-2013, 06:01 PM
If your description of poor starter turn-over is correct, they are full of it. Fuel pump has nothing to do w/ engine turn-over.
Also engine runs OK once started, so fuel pump only affecting starting is very unlikely IMO.
joenintiesc
04-14-2013 07:29 AM
ysbarney
10-01-2012 06:04 PM
huhdo
08-30-2012 09:06 PM
Reggi's-accord
06-06-2012 07:17 PM
HondaAficionado
11-30-2010 05:24 PM
Quick Reply: Accord trouble turning over - "da ta ta ta ta ta vrooom" - 2005
