Car won't start if parked in sun all day - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 06-16-2006, 03:54 AM
stevec
Default Car won't start if parked in sun all day
I have a '97 Accord Coupe 3.0l V6 with about 56K miles that has been having a problem. If left out in the sun all day, it will not start. Usually I don't drive it to work, but today I did, and inadvertently parked in a very sunny spot. I got to the car at 5 PM to drive home and found it extremely hot inside. Although it cranked very strong, it would not start. I opened the gas cap but there was no pressue built up. I waited half an hour and tried again - no dice. I waited an hour more, until 6:30, and it started with absolutely no problem. I'm not an expert, but it's got to be some sort of fuel delivery problem. Any ideas?
Thanks,
Steve C.
Old 06-16-2006, 04:00 AM
deserthonda's Avatar
Default RE: Car won't start if parked in sun all day
Hello Steve,,,,,,,,,
First off welcome to HAF...........
It sounds like you got a typical MAIN RELAY problem ..
try this ..
http://www.hondaaccordforum.com/NO_S...m_17302/tm.htm
Old 06-16-2006, 02:13 PM
you can also remove main relay and if you are proficient with a soldering iron, resolder all the joints after carefully prying part relay. The components on the relay hardly ever fail but there are a lot of them that have what are called "cold solder joints" and you can fix them yourself with a $10 radio shack iron and $4 solder tube. Better than pay 50-70 from the dealer for that thing.
Old 06-16-2006, 10:37 PM
main relay problem fo sho
Reply
Thread Thread Starter Forum Replies Last Post
Power windows and sun roof plus car starting 95_Honda_Accord_Ex_Sedan General Tech Help 8 01-12-2013 10:33 AM
1990 Honda Accord Flashing S on the dash and wont start are sitting in sun or hot. Devil Strider General Tech Help 1 05-31-2012 09:21 PM
Honda Accord 1987 LX -- While PARKED, RPM raises and drops constantly Honda Enthusiast General Tech Help 11 11-26-2010 09:43 AM
Fan Cycles on after car is parked 19962door General Tech Help 1 05-17-2010 08:41 PM
Oil leak in 2001 4 cyl. accord only when parked downhill JohnnyFive General Tech Help 4 04-22-2008 09:33 AM
Tags
accord, acura, cap, car, cl, coupe, gas, honda, hot, left, parked, start, starting, sun, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
