Sponsored by:
Sponsored by:
02 accord headlight problem
Old 03-09-2010, 10:13 AM
Jager06's Avatar
Default 02 accord headlight problem
Drivers headlight low beam keeps burning out. I think I may have an electrical problem. Can you please help me start trouble shooting it. Thanks
Old 03-09-2010, 11:47 AM
First check a non-electrical problem. The little adjustable rubber bumpers when you close the hood might be too tight. Maybe they hammer the headlamp housing every time you close the hood?
Then measure system voltage. If your voltage regulator is flaky, you might see voltage spikes above 15v or whatever. Those would be bad for lamp lifespan, but it's difficult to see why it would ONLY happen to that one bulb.
Old 03-11-2010, 06:52 PM
Jager06's Avatar
Checked the voltage at the bulb connecter and it was 16.4V with the car running. Then checked the battery with the car running and it was 16.6V. Now what should I do? Is it the voltage regulator? If so where is it located at?
Thanks, Jager06
Old 03-11-2010, 07:21 PM
I would think that it is in the alternator.
Old 03-11-2010, 09:31 PM
#19 is the regulator in a 4-cyl alternator. The V-6 alternator doesn't show any parts breakout, so I don't know if you can get a regulator.
4x4Accord
12-26-2011 04:35 PM
slow1500
03-18-2009 07:47 PM
CoryTheStory
11-18-2008 03:00 PM
lyle
06-04-2008 12:36 PM
Quick Reply: 02 accord headlight problem
