Sponsored by:
Sponsored by:
Catalytic COnverter or O2 sensor?
Old 05-19-2013, 05:45 PM
Airdorn's Avatar
Default Catalytic COnverter or O2 sensor?
Hi all.
I have code 0420. Using the scan tool, I see that the downstream O2 sensor wildly fluctuates between 1/2 volt and nearly no volts. I understand that it should pretty much be stable at right around 1/2 volt when the engine is up to normal operating temp.
I already took the catalytic converter off and hosed it down with soap & water and all that.
Without blindly throwing parts at this problem, how can I find out if it is the O2 sensor or the catalytic converter itself?
The cat has about 165,000 miles on it and it had a terribly dirty intake air filter and throttle body. The ECR passage was pretty clogged, too. I cleaned that stuff up.
Thanks!
PS - Car is a 1998 Accord EX 2.3 liter VTEC 4-cyl.
Old 05-19-2013, 06:09 PM
Old 05-19-2013, 11:09 PM
Airdorn's Avatar
Ya, I'm guessing its the converter and not the O2 sensor.
acez29
11-25-2012 07:19 PM
reservoirdog
09-25-2010 08:58 AM
Parker96
04-21-2009 09:24 AM
jmarshy
05-31-2007 01:45 PM
msmcv73
03-27-2006 05:49 PM
Quick Reply: Catalytic COnverter or O2 sensor?
