CEL strangeness - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 03-20-2017, 03:45 PM
Default CEL strangeness
About 6 months ago I had a O2 sensor problem on a 1991 Accord EX. I replaced the O2 sensor and the problem went away (rough running after about 5 minutes). The diagnostic codes pointed me in the right direction on that episode. Now a few days ago the CEL light started coming on as a flash but not remaining on. Today the old problem returned with a twist. After about 5 minutes the car starts running rough with a loss of power. If I continue at low speed eventually it clears up AND the CEL comes on. As long as I run it with the CEL on everything is fine. If I turn off the ignition the CEL goes off and stays off until the above routine is done again. I've jumped the code connector by the glove component and the manual says that should make the CEL light stay on and give me the code. The CEL light does not stay on even when jumped. Any clues?
Thanks,
Bob
Old 03-20-2017, 04:06 PM
Fals alarm. I narrowed the jumper wire ends and put in the sockets again. Now all behaves as the manual suggests. Code I get is 1 so we're back to the O2 sensor. Any reason why it should fail within 1000 miles?
Bob
Reply
Thread Thread Starter Forum Replies Last Post
CEL and code P0441 rdrx7 General Tech Help 9 08-25-2009 07:49 PM
89 accord Check engin Light (CEL) dandy General Tech Help 5 04-17-2007 08:40 PM
93 Accord...CEL Code 12 AccordEX General Tech Help 1 04-10-2007 08:21 PM
CEL/Maintenance Reguired light Diagnostic? schmidty General Tech Help 2 03-13-2007 01:57 PM
Looking for the sequence to check the CEL light Summerskiss2002 General Tech Help 1 12-04-2005 10:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
