Sponsored by:
Sponsored by:
Signal Lights do not blink
Old 11-10-2006, 12:49 PM
shahk
Default Signal Lights do not blink
I have 2001 Accord LX. Left,Right and hazard signal lights do not work although all the bulbs are lit. What could be the problem and how do I solve it? Thanks in advance for the input.
Old 11-10-2006, 01:40 PM
sir_nasty's Avatar
Default RE: Singal Lights do not blink
if they all just went out suddenly I'd guess you blew a fuse, look at your fuses under the dash and under the hood.... if that's not it you could have a bad combo switch... but most likely it's a fuse problem
Old 11-10-2006, 10:57 PM
deserthonda's Avatar
Default RE: Signal Lights do not blink
underhood fuse box chk fuse # 49 15 amps,, under dash driver fuse box chk fuse # 10 7.5 amps
coild be a bad turn signal/hazard relay located in the undrdash driver fuse box
Old 11-12-2006, 02:27 PM
YeuEmMaiMai's Avatar
take relay out and put a new one in. if problem goes away, you know what it was.... I doubt it is a switch....
Gangsta101
02-10-2013 01:50 AM
trucknut88
08-29-2011 08:39 AM
The_OS
06-04-2010 04:31 PM
fusionstar
06-28-2009 05:08 AM
Starfox
06-15-2009 06:42 AM
Quick Reply: Signal Lights do not blink
