Sponsored by:
Sponsored by:
Clock backlight on 2000 Odyssey LX
Old 01-09-2006, 02:29 PM
shimmyp
Default Clock backlight on 2000 Odyssey LX
Please tell me how to change the clock backlight on a 2000 Honda Odyssey LX. The Clock is on a separate panel of the dashboard together with the Hazard Flasher On/Off switch. Can I try pulling out the clock together with the Hazard switch or do I have to take apart the whole dashboard? Please help me. I drive at night and I can't see what time it is.
Old 01-09-2006, 04:04 PM
Lance Link's Avatar
Default RE: Clock backlight on 2000 Odyssey LX
You're not alone. I had the same problem.
Old 01-10-2006, 12:49 PM
6thgen's Avatar
the clock assembly, sounds the same as the accord) should be attached w/ clips, so it should snap out. Pull from the bottom.
Old 09-01-2006, 06:35 PM
lschaff
So frustrating! I have a 2000 Odyssey, and the backlight quit working after about 3 years. When I went to the car wash about a year ago, it magically began working again. Yesterday, I wiped down the dashboard, and just as magically, the backlight doesn't work anymore.
I clicked on the service bulletin above, and it said to remove the instrument panel. I'm assumming this is pretty much most of the dashboard. It sounds like a bigger deal than I want to get into, so can someone please comment on how indepth this process is?
Old 09-01-2006, 07:54 PM
Chiovnidca's Avatar
ORIGINAL: 6thgen
Nope, not on the odyseey, they take a little more work than that. You have to remove the bezel around the heater controls to get to the screws hloding the gauge bezel down. (which has to come out to replace the bulb on the back of the clock)
Old 09-02-2006, 12:46 AM
lschaff
Thanks for the info. I was afraid to pry too hard on the trim around the clock for fear of breaking it - glad I didn't do that!
grock1722
04-28-2012 03:34 PM
IntegraGSR
10-05-2010 08:43 PM
alexh90
02-22-2007 01:20 AM
doctorpowder
09-12-2006 11:26 PM
sci bucks
01-22-2005 12:26 PM
Quick Reply: Clock backlight on 2000 Odyssey LX
