Sponsored by:
Sponsored by:
Code PO 401
Old 12-28-2006, 05:35 PM
MichaelEXL's Avatar
Default Code PO 401
The check engine came on while I was in Atlanta on Saturday, I had to drive to the nearest dealer where I was staying. Had to leave the 96 Accrod EX-L at Nalley Honda in Union Cityjust outside of Atlanta. Come to find out the ports needed to be cleaned and had to perform induction system cleaning.
Thecode is in the subject line, I have never heard of thisproblem all, the labor was $310.82 the total bill was $383.72
Old 12-28-2006, 05:49 PM
MichaelEXL's Avatar
Default RE: Code PO 401
The Honda dealer here in daytona Beach, FL get $42.00 an hour for labor, while Nalley Honda gets $96.00 an hour.
Old 12-28-2006, 06:20 PM
sir_nasty's Avatar
It's just an EGR port problem apparently.... that sucks on the charges, it sounds like it was something that a little bit of work and a can of sea foam would have cleared up...
Old 12-28-2006, 07:56 PM
hondadude's Avatar
Well here's a link to show what they did to fix the problem
http://members.troublecodes.net/hond...5AccordEGR.htm
I'd like to know how many hours they charged.
FWIW Seafoam would not have helped this problem
Old 12-28-2006, 08:05 PM
sir_nasty's Avatar
I probably should have clarified... I don't think a can of Seafoam alone would have fixed it but a little bit of work would have... I just threw the comment about seafoam in there because I assumed that if something was clogged due to build up then the rest of the motor probably could have used a cleaning too.... Thanks for that post though for a DIY fix, great, easy to follow information....
Old 12-28-2006, 11:15 PM
MichaelEXL's Avatar
Thanks I just take it to Jon Hall Honda when it comes to the engine, as I am not mechanically incline here.
Old 12-28-2006, 11:44 PM
ORIGINAL: hondadude
Hello Bill..again a very excellent post with the Stuff to back it up...
I like your style...Thank You for your information [sm=americanasmiley.gif]
Old 12-29-2006, 01:48 PM
maro's Avatar
I printed out the DIY EGR PORT fix and did it in a hour with only a socket wrench, a poker and some cleaner...and with hardly any knowledge of my intake system. The DIY instructions are clear and precise with photos to boot. I can't beleive cleaning the ports was so expensive. Like I said, I did it in an hour, outside in the brisk philadelphia air, with no experience.
things to do this week-end with help from this site.
Changing out my Manual Trans Fluid... with Honda MTF,
Changing out my cooling system,
Replacing Plugs.
Cleaning Fuel Injectors.
Old 12-29-2006, 01:58 PM
sir_nasty's Avatar
Be certain that you don't use bosch spark plugs... .they don't work well with honda's, stick to the green anti-freeze and a funnel with a long neck and a small tip can help IMMENSELY when re-filling the MT Fluid.... Just some side notes...
Old 12-30-2006, 09:58 AM
MichaelEXL's Avatar
I also heard about not using Bosch plugs as well
rykertest
01-27-2012 06:43 PM
tingjunkie
09-17-2010 06:37 PM
will'i'am
09-16-2010 01:19 PM
Stener75
07-25-2010 08:21 PM
madsteez
01-18-2009 07:43 PM
Quick Reply: Code PO 401
