Sponsored by:
Sponsored by:
Common DIY and Info. Threads
Old 06-15-2011, 09:42 PM
Default Common DIY and Info. Threads
Here is a list common threads referenced in the general tech help section by a lot of members on here.
I didn't put all of the DIY threads in here, and I am likely missing some useful ones.
Attn. Mods: I am locking this thread, but feel free to add links to it.
General Threads
Online Shop Manuals
https://www.hondaaccordforum.com/for...34/#post340068
CEL (Check Engine Light) Code Retrieval
OBD 1 ECU and TCU Codes
Set BASE idle 2002 & earlier
Timing Belt Tensioner Tip (1990-2002)
Coolant Temperature Sensors Detailed Explanation of Each Sensor
Automatic Transmission Fluid Change
Bleeding your clutch
Parts Compatibility
Honda Electrical Connector Terminal Replacement Procedures
Generation Specific Threads
4th Generation Accord (1990-1993)
EGR Port Cleaning
Rotor Over Hub Conversion
Wheel Stud Replacement
5th Generation Accord (1994-1997)
EGR Port Cleaning
FITV Cleaning
IACV Cleaning
ABS Bleeding
DIY – Repair: 1994 – 1997 Accord - Power door lock (actuator) buzz sound or cycling
6th Generation Accord (1998-2002)
EGR Ports V6
Knock Sensor
Clean your IACV (Idle Air Control Valve) | Honda Accord DIY
HVAC Codes
7th Generation Accord (2003-2007)
HVAC Diagnostic Trouble Codes
Easy way to test that interior Fan Blower Motor works (2003 – 2014 Accords)
Owner's Manuals 2004-2007
Checking blower-control circuit 2003-2006
Blower Motor Transistor Replace/Repair
Serpentine Belt Tensioner V6
8th Generation Accord (2008-2012)
Ventilation Fan Noise
https://www.hondaaccordforum.com/for...2-4l-i4-33793/
https://www.hondaaccordforum.com/for...-guides-33830/
https://www.hondaaccordforum.com/for...ictures-33778/
2008-2012 Accord Maintenance Guide 4 cylinder
9th Generation Accord (2013-2014)
https://www.hondaaccordforum.com/for...ned-off-52000/
https://www.hondaaccordforum.com/for...-scrape-52001/
How to disable Active Noise Control (ANC) while retaining Hands Free Link (HFL)
https://www.hondaaccordforum.com/for...08/#post342552
markus9175
03-27-2009 10:35 PM
PAhonda
01-20-2009 10:43 PM
mjhenks
01-16-2009 11:42 PM
AyashiFX55
06-05-2008 07:55 PM
Quick Reply: Common DIY and Info. Threads
