Sponsored by:
Sponsored by:
Dipped Headlights Keep Blowing - 04 Accord
Old 12-27-2010, 08:00 AM
wodders's Avatar
Default Dipped Headlights Keep Blowing - 04 Accord
Hi there
I have a 2004 2.2 Diesel Accord and my dipped headlights keep blowing after a few weeks - at this stage I must be the star customer in local garage for replacement lights.
Fuses have been checked and replaced but at best I get about 4 or 5 weeks for each bulb - driving me nuts.
Any thoughts? Thanks in advance.
Old 12-27-2010, 03:57 PM
What is a "dipped" headlight? Has the headlight been modified?
Old 12-28-2010, 06:23 AM
wodders's Avatar
Sorry for confusion - I mean normal headlights (as against full beams) - hope clarifies?
Cheers
Old 12-29-2010, 08:10 PM
Measure the system voltage; including while revving engine to higher RPM. Possible bad voltage regulator running at too-high voltage causes short lamp life.
Old 12-30-2010, 09:48 AM
wodders's Avatar
Thanks for rely - excuse ignorance at this end- how do I go about measuring the voltage?
Thanks in advance!!
Old 12-30-2010, 10:46 AM
Smile Hi New Member
My Friend Mr. Googles found this help item..
Welcome to the forums..
http://uk.answers.yahoo.com/question...8081607AAsyBfp
Old 01-01-2011, 11:10 AM
Voltmeter across the battery terminals.
If the regulator isn't doing a good job of holding 13 volts (at different conditions), that may be the reason.
Old 01-01-2011, 11:18 AM
Instructions w/ the bulbs warn against contamination of the bulb surface w/ grease or body oils (damn I'm not that oily!). I've always tried to be careful, but never wore gloves and so far no particular problems.
If you don't have a Volt-Ohm Meter, you can buy a Battery Monitor from Walmart for about $15. This is a very handy device to plug into the cigarette light socket and monitor voltage full time. I keep one and frequently check cars to see what voltage is doing.
StrikingAccord
03-29-2015 11:22 PM
skillet256
03-25-2013 08:46 PM
Da Flash
06-06-2011 10:03 PM
steviebix
03-24-2008 10:03 AM
kmart3
01-12-2008 08:34 PM
Quick Reply: Dipped Headlights Keep Blowing - 04 Accord
