Sponsored by:
Sponsored by:
Defrost,heater,AC Blower not working
Old 11-14-2008, 09:52 AM
MSA
Default Defrost,heater,AC Blower not working
1994 Honda Accord.
The blower works or has been working intermediately but now hasnt worked in a few days.
Does this sound like the motor itself or just a blower motor resistor.
I understand that the blower motor (if thats what it is) is not a DIY job so I think I'll start with the resistor. Where is it located? Or is replacing the resistor a non DYI job as well.
Thanks
Old 11-14-2008, 10:03 AM
hondadude's Avatar
Default RE: Defrost,heater,AC Blower not working
Usually when the resistor goes bad the fan will still run on high speed;
The 'Caveman' test can prove worn out brushes in the motor.
When the motor will not run, reach up under the glove box and smack it.
The replacement of the motor is not beyond DIY.
You can look up under the glove box to see it.
I think you have to peel back the carpet to have room to drop it out.
3 screws and one plug. GRAVY JOB [sm=happy046.gif]
Old 11-14-2008, 11:02 AM
MSA
ORIGINAL: hondadude
So, if it's not blowing at all then it's most likely the blower motor.
Is that a Honda only part?
Old 11-14-2008, 01:26 PM
jcocker03's Avatar
it never hurts to call your local parts stores first to see if they carry the part, thats what i always do because the dealer is usually more expensive. but with the dealer you get oem parts.
Spetsnaz2.0
10-19-2019 09:16 AM
Joslinm
10-25-2013 10:43 AM
Honda Man For Life
04-09-2012 09:38 AM
Jonah805
07-26-2011 06:08 PM
skeenr
01-17-2007 11:30 PM
Quick Reply: Defrost,heater,AC Blower not working
