Sponsored by:
Sponsored by:
Cruise control operation is dependent on outside temp.
Old 03-09-2011, 09:21 PM
colorado_accord's Avatar
Default Cruise control operation is dependent on outside temp.
Seems my cruise control will only work correctly if the outside air temp is 50 degrees or above, anything below that and it is really intermittent, sometimes it will hook up other times it will slow way down and then level out way below what I set it to originally. All indicators work correctly. I figure it could be the cable, perhaps is sticking inside the housing? When I get time I'll take it apart and take a look. Anyone else have this issue before??
Old 03-20-2011, 05:58 PM
We have the opposite problem. The cruise control works intermittently on our 05 EX if the temperature is around 85 F or above. It is fine in the winter. Am still researching it if anyone has some advice. KPgr8 Ken
rimidalvr1966
10-28-2013 10:35 AM
Digit
03-01-2011 08:47 PM
segen77
12-09-2007 06:55 PM
raf105
09-28-2007 02:55 PM
longhornjohn
08-26-2006 07:32 PM
Quick Reply: Cruise control operation is dependent on outside temp.
