cubby hole door
cubby hole door
hey everybody, been a member for a few years, but just got the car back from the in laws. anyway, i need some help if ya don't mind.
the little cubby hole in front of the gear shifter, the door that clicks down and closed, doesn't click closed. it won't stay closed. just curious if there is some special part that i can replace or where to start with this, to get it working. it would be nice to close for a little more visual security. some items need to be out of sight, per state law. that seems to be a perfect spot.
car info
2005 automatic coupe.
thanks ahead of time.
car info
It called the center pocket assembly. Since it won't close, you have to remove the center pocket assembly and try tightening the 2 screws (one on each side), if that doesn't work, you may have to replace it.
1. Removing the center pocket assembly is shown in step 5 of this audio installation instructions: http://www.handa-accessories.com/acc...cord-audio.pdf
2. Tightening the 2 side screws (one on left and one on right) are shown as Procedure B of this attached TSB.
