D3 or d4 (automatics only) - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 07-27-2010, 05:43 PM
Default D3 or d4 (automatics only)
Do u drive your honda automatic in d3 or d4 which is better for gas mileage, acceleration and so on thanks in advance
Old 07-27-2010, 06:57 PM
EXV6NIGHTHAWK's Avatar
D3 will give you more power, but it will also use more gas. You shouldn't need to use D3 unless you are going up a steep hill (to keep the transmission from constantly down shifting and up shifting), or towing, for the same reason. If you push the accelerator down, the transmission should downshift on it's own, to give you more power (for passing). I certainly wouldn't ride around in D3, because that would cause the engine to run faster, and hence burn more gas.
Old 07-27-2010, 07:09 PM
g22cd5's Avatar
Supper Moderator
dont run around in d3 stay in d4...
Old 07-27-2010, 10:06 PM
d4 it is then bretheren
Old 07-28-2010, 05:46 AM
g22cd5's Avatar
Supper Moderator
If your like me and you don’t like pushin the gas pedal to the floor just to downshift just simply pull back to d3 if you need to accelerate a bit.
Reply
Thread Thread Starter Forum Replies Last Post
Problems with 2003 automatics Grand Rapids Off Topic 15 02-19-2014 12:16 AM
Performance automatics? Tek310 Engine & Internal 6 07-27-2011 11:15 PM
Turbo for automatics? Joseph Engine & Internal 13 12-16-2007 08:51 PM
are manual transmissions more reliable and cheaper than automatics? thunder_x Off Topic 8 02-03-2007 05:01 PM
what is the purpose of the overdrive or sport button on automatics? thunder_x Off Topic 2 07-04-2006 02:31 PM
Tags
1992, 1994, 2000, 92, 94, acceleration, accord, acord, automatic, d3, d4, drive, faster, honda, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
