D3 or d4 (automatics only)
D3 will give you more power, but it will also use more gas. You shouldn't need to use D3 unless you are going up a steep hill (to keep the transmission from constantly down shifting and up shifting), or towing, for the same reason. If you push the accelerator down, the transmission should downshift on it's own, to give you more power (for passing). I certainly wouldn't ride around in D3, because that would cause the engine to run faster, and hence burn more gas.
thunder_x
02-03-2007 04:01 PM
thunder_x
07-04-2006 01:31 PM
