D3 or d4 (automatics only)
Old 07-27-2010, 04:43 PM
yungjody254's Avatar
Default D3 or d4 (automatics only)
Do u drive your honda automatic in d3 or d4 which is better for gas mileage, acceleration and so on thanks in advance
Old 07-27-2010, 05:57 PM
EXV6NIGHTHAWK's Avatar
D3 will give you more power, but it will also use more gas. You shouldn't need to use D3 unless you are going up a steep hill (to keep the transmission from constantly down shifting and up shifting), or towing, for the same reason. If you push the accelerator down, the transmission should downshift on it's own, to give you more power (for passing). I certainly wouldn't ride around in D3, because that would cause the engine to run faster, and hence burn more gas.
Old 07-27-2010, 06:09 PM
g22cd5's Avatar
Supper Moderator
dont run around in d3 stay in d4...
Old 07-27-2010, 09:06 PM
d4 it is then bretheren
Old 07-28-2010, 04:46 AM
g22cd5's Avatar
Supper Moderator
If your like me and you don’t like pushin the gas pedal to the floor just to downshift just simply pull back to d3 if you need to accelerate a bit.
Grand Rapids
02-18-2014 11:16 PM
Tek310
07-27-2011 10:15 PM
Joseph
12-16-2007 07:51 PM
Quick Reply: D3 or d4 (automatics only)
