"D4" gear light flashing ?! - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 09-02-2011, 05:32 PM
Default "D4" gear light flashing ?!
95 Accord v6, the light around the drive gear up on the dash starting flashing, steady flash, and Im wondering if thats some kind of transmission problem? Any info is appreciated.
Old 09-02-2011, 05:40 PM
Almost A Senior Member
Might be a trans. code but I'm not sure that applies if it's constant on while you're not jumping the service connectors.
Old 09-02-2011, 07:42 PM
A steady flash (going on/off presumably) indicates an error code is stored. Short service check connector and D4 will blink the code/s. Check DIY forum for guidance on extracting codes, same procedure as engine codes.
Old 09-03-2011, 11:20 PM
Honda_Lady's Avatar
if it's flashing you definitely need to check the code. if it's just on and your not in that gear it could be the computer. i had a problem like that with it just on and not in that gear with shifting problems and replace the TCU with a used one and it fixed that particular problem. definitely more info needed to tell you any more.
Reply
Thread Thread Starter Forum Replies Last Post
1994 honda accord auto flashing "d" ? PELLEY General Tech Help 2 10-01-2013 06:07 AM
Buy "used" or "rebuilt" TCM? ysbarney General Tech Help 11 10-01-2012 06:04 PM
"Wheel Weight Lip" VS "No Wheel Weight Lip" Reggi's-accord Tires & Wheels 2 06-06-2012 07:17 PM
Going from an OEM "V" rated tire to an "H"...Is this okay? HondaAficionado General Tech Help 10 11-30-2010 05:24 PM
No Speedo, No cruise control, Flashing "s" light skysa General Tech Help 0 11-09-2009 06:24 AM
Tags
1993, 95, accord, blinks, d4, dash, drive, flash, flashes, flashing, gear, honda, integra, light, number
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
