Sponsored by:
Sponsored by:
"D4" gear light flashing ?!
Old 09-02-2011, 05:32 PM
chrisjames105's Avatar
Default "D4" gear light flashing ?!
95 Accord v6, the light around the drive gear up on the dash starting flashing, steady flash, and Im wondering if thats some kind of transmission problem? Any info is appreciated.
Old 09-02-2011, 05:40 PM
MessAround's Avatar
Almost A Senior Member
Might be a trans. code but I'm not sure that applies if it's constant on while you're not jumping the service connectors.
Old 09-02-2011, 07:42 PM
A steady flash (going on/off presumably) indicates an error code is stored. Short service check connector and D4 will blink the code/s. Check DIY forum for guidance on extracting codes, same procedure as engine codes.
Old 09-03-2011, 11:20 PM
Honda_Lady's Avatar
if it's flashing you definitely need to check the code. if it's just on and your not in that gear it could be the computer. i had a problem like that with it just on and not in that gear with shifting problems and replace the TCU with a used one and it fixed that particular problem. definitely more info needed to tell you any more.
PELLEY
10-01-2013 06:07 AM
ysbarney
10-01-2012 06:04 PM
Reggi's-accord
06-06-2012 07:17 PM
HondaAficionado
11-30-2010 05:24 PM
skysa
11-09-2009 06:24 AM
Quick Reply: "D4" gear light flashing ?!
