D4 Light Won't Stop Blinking
I have a 1993 Honda Accord SE and I just put a low milage JDM transmission in it. I did the swap perfect, nothing left over everything plugged in. I connected the service plug together with a wire and the D4 light still just blinks. The transmission level is perfect. I hear a slight high pitched sound coming from the engine bay, but not loud enough to hear inside the car. When I took it for a drive is is very sluggish through the gears. Do you guys think that may have to do with the speed sensor? I did not un-plug the fluid from it, just pulled it out and stuck it back in. Let me know what you guys think. Thank you, Philip.
RE: D4 Light Won't Stop Blinking
you need to read the # of flashes on the dash board
Long flash = 10
short flash = 1
so if you get a long flasf, a slight pause and 4 shorter flashes, it is code 14 ... count the flashes more than onces to be sure you get the correct code and also in case there is more than 1 code stored ..
So ,jump the connector, put key on and start counting .
Long flash = 10
short flash = 1
