difference between F23A1 & F23A4??? - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 07-19-2011, 02:43 AM
Default difference between F23A1 & F23A4???
my car is 2001 accord lx 2.3L 4dr sedan vtech
  • when i am looking for parts for my car many times i will encounter the question which engine i have and i do not know what is the difference LX -- L4 - 2.3L 2254cc type F23A4 - MFI GAS SOHC
  • LX -- L4 - 2.3L 2254cc type F23A1 - MFI GAS SOHC
how do i find out exactly which one my car is?
Old 07-19-2011, 03:07 AM
either by ur VIN I think its the 8th or 10th digit (one will b a 1 for ur year so it will be the other one) that will give u the engine code which u can put into google (try "honda vin decoder") and follow links. Also it will b stamped on the engine block somewhere along w/ the serial number.
Old 07-19-2011, 03:30 AM
i checked out the vin and there is nothing in the vin indicating whether its a F23A1 & F23A4
Old 07-19-2011, 04:55 AM
Found ur answer. I just use google (for everything) I put in "f23a1 f23a4" and it gave me anything w/ those 2 engines in it. I found exactly what u were lookin for on Wikipedia (that & google are probably the 2 best sites).
Under Wikipedia is "Honda F Engines"
F23A1 is 150 hp/152 ft-lb
F23A4 has ULEV certification is 148 hp/150 ft-lb, different exhaust manifold, a 32-bit ECU which uses a wideband O2 sensor when compared to the F23A1.
There is more look it up.
Old 07-19-2011, 07:40 AM
There is a sticker on the timing belt cover with the engine code on it. Check to see if it is still in tact.
Old 07-19-2011, 09:26 AM
thank you for ur great answers guys
Old 07-22-2011, 03:48 AM
I could be wrong but I read somewhere that the 4 (is the ULEV engine) and the 1 is the (VTEC engine)
ULEV 148hp
VTEC 150hp
hope that helps
Old 07-22-2011, 04:48 AM
Honda-4-Life - they both are VTEC engines just one of those engines is ULEV
Old 07-22-2011, 06:51 AM
Quote:
ULEV 148hp
VTEC 150hp
hope that helps
They're both V-TEC, but the ULEV engine used a more restricted exhaust manifold with a front wideband O2 sensor so it lost 2hp, but if you use the exhaust manifold from the non ULEV you will get back that 2hp
Old 07-24-2011, 01:23 PM
does anyone know how much hp to the wheels the f23a1 has?
i know the website says 150hp but im pretty sure thats not the wheels
Reply
Thread Thread Starter Forum Replies Last Post
difference between euro and american spec? euroaccord Appearance 1 05-31-2013 11:11 PM
Difference between HB4 & 9006 dragonle87 General Tech Help 2 07-11-2009 02:06 AM
F23A1 or F23A4 dstarnik Engine & Internal 5 09-17-2008 11:48 AM
F23A1 VS F23A4 98accordlx Engine & Internal 10 03-11-2008 06:02 PM
difference between short ram and CAI? blarf Engine & Internal 21 09-06-2005 02:44 AM
Tags
23l, accord, block, difference, engdesg, engine, f23a1, f23a4, fi, have, honda, l4, serial, whats, wich
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
