Heat/AC Problems for a 2000 Honda Accord
I've got a 2000 Accord EX. Since this summer I've been having problems with my heat/ac. The heat or AC will turn off, but the fans will still blow. When this happens the mode buttons go blank and cannot be changed. The temperature contrial dial will no longer change the temperature when this happens as well. Also, it seems to happen more when the AC is on. Either cooling the car or defogging the windows. As previously mentioned I can still control the fan.
I'm at a loss for how to fix this, mostly because I have very,very limited knowledge about cars.
Sounds like the heater mode control panel is losing power. This'll involve digging into the dashboard & doing electrical tests. Got a multi-meter? I ask because you said you have limited knowledge about cars.
skijour
08-15-2012 08:31 PM
