Drivers window ,, help
Old 09-20-2014, 07:23 PM
woody31's Avatar
Almost A Senior Member
Question Drivers window ,, help
On my 96 accord 4 door, the drivers window rocks back in forth in the channel, when you roll it up u have to hold the window in the slot or it will push out at the top,, any ideas?? is it a easy fix ?? thanks
Old 09-20-2014, 08:31 PM
You probably need to remove the door panel and adjust the glass.
Open the online manuals thread in this link: https://www.hondaaccordforum.com/for...threads-40780/
The 94 accord shop manual will show the procedure.
Here is a video on replacing the run channel.
Watch How To Replace A Window Run Channel ( 97 Honda Accord) | EricTheCarGuy Episodes | How To Videos | Blip
You can see how to remove the door panel. You may want to clean and lubricate that run channel too.
Old 09-20-2014, 08:32 PM
There is also a link in that common diy thread for glass jumping the track that you should check out.
Let us know how this turns out.
Good luck.
Good luck.
Old 09-21-2014, 08:03 AM
woody31's Avatar
Thank you for your time and replies, What type of lube do I use in the run channel?
Old 09-21-2014, 08:17 AM
Well the "good stuff" costs a bit - ~$20 Shin-Etsu Grease.
Other than that you can use some other type of lube, I've use white lithium before with some luck.
Old 09-21-2014, 03:30 PM
woody31's Avatar
i looked and do not see a link or anything related,,can someone post a link to the proper repair or diagnosis, thanks
Old 09-21-2014, 04:46 PM
The link is part of this thread. I posted the instructions from a Honda Service News article there previously. You would reposition the window regulator and front channel.
It is under "94-97 Door glass jumps track".
Old 09-21-2014, 07:47 PM
woody31's Avatar
thanks,,it seems difficult,,can this be done at home or does it need to go to the shop,,
Old 09-21-2014, 07:56 PM
It is not very difficult and can be done at home.
Michael Bomes
09-09-2012 03:12 PM
Major
06-02-2007 06:10 AM
Crabby
06-01-2007 09:11 AM
adamc44
02-11-2007 03:02 PM
lostinspace
05-31-2006 10:17 PM
Quick Reply: Drivers window ,, help
