Sponsored by:
Sponsored by:
Engine knocking while idle then died
Old 08-30-2016, 06:53 AM
jblackmon's Avatar
Default Engine knocking while idle then died
I drive a 2006 Honda Accord EX V6. This morning I drove in to work about 30 minutes. While sitting in the parking lot with the car running the engine started knocking really severely so I turned the engine off. I tried cranking again and it started, but continued knocking and then just died. I let it sit for a minute and tried again, it knocked while turning over, but then seemed to run like normal. I will try starting the car again on my lunch break to see what happens. What would cause this?
1. I filled up the gas tank yesterday evening.
2. I have a failing power steering pump.
3. I am due for an oil change.
Thanks in advance!
Old 08-30-2016, 07:10 AM
Do you regularly check the oil level?
The oil-life monitor calculates its % based on all your driving habits, but there it no measurement of how much oil is in the pan.
Old 08-30-2016, 07:14 AM
jblackmon's Avatar
No, I don't check the oil level regularly. :-/
tlhfirelion
08-22-2016 12:50 PM
iStagl
07-27-2012 07:38 PM
jlawrence47
04-16-2011 01:13 PM
SolEX01
08-10-2010 05:04 PM
HondaAccord93
03-18-2009 08:40 PM
Quick Reply: Engine knocking while idle then died
