Sponsored by:
Sponsored by:
EVAP Control Canister
Old 03-13-2012, 11:36 PM
1madracer's Avatar
Default EVAP Control Canister
ive got a 04 thats throwing a p2422 "EVAP Control Canister " it was a flood car and when i was looking into them i noticed that they were full of nast flood water.. can i bybass EVAP Control Canister or just dump the water out????
Old 03-14-2012, 07:23 AM
There is no way to simply bypass that system. You may want to try draining the water to see if that fixes the problem. The code is for the vent shut valve and the water could have corroded the valve. It my need to be replaced. Also check the electrical connectors for corrosion.
On older accords, that valve would get corroded due to exposure to salty roads. I haven't read about problems with that valve in 03+ accords, so you may be able to find a cheap replacement at a junkyard.
Old 03-21-2012, 05:08 PM
1madracer's Avatar
thnx.... i got lucky and a local salvage yard got in a wrecked 05 and that was my donor car lol
Dakotademon7
12-17-2014 08:53 PM
jfidelh
12-01-2011 01:39 PM
JimBlake
DIY Answers.
08-06-2009 01:36 PM
violated
12-01-2007 10:05 AM
bww
09-23-2007 10:24 AM
Quick Reply: EVAP Control Canister
