Sponsored by:
Sponsored by:
Exhaust Manifold Shield...How do I remove it ?
Old 09-29-2014, 11:17 AM
Alone's Avatar
Default Exhaust Manifold Shield...How do I remove it ?
I got a 1991 Honda Accord DX and I'm trying to remove the exhaust manifold shield for resurface and painting,
seems easy enough, but then as Im trying to take it out after removing the 3 screws, the A/C line the the radiator are in the way.
Is there a way to remove it without removing the A/C line and the radiator ?
Anyone done this before ?
Old 09-29-2014, 11:43 AM
Looks to me like O2 sensor must be removed for sure. This should allow unit to come more directly upwards. An O2 socket is necessary to remove.
Old 09-29-2014, 03:02 PM
Alone's Avatar
OH yeah, forgot to mention, yes, i removed the 02 sensor too, might be able to squeeze pass the a/c line but seems like gonna have to remove the radiator or just the fan if removable without having to remove the radiator.
Old 09-29-2014, 04:48 PM
AC line won't move much so removing radiator fan is likely necessary.
Fans can be removed w/o removing radiator and radiator can be tipped forward if topside guide brackets are removed.
Removing radiator fans is a bit of pain requiring removal of underbody dust shield to access the lower side retaining bolts and loosen them enough to remove the fan shroud. I've found that I have to completely remove bolts to manage reinstallation.
sp33dd3mon343
03-23-2012 06:34 PM
Peli
07-18-2011 10:12 AM
JerseyTuscani
07-02-2007 05:21 PM
Drpepper
05-23-2007 10:03 AM
19Accord97
05-18-2006 12:52 AM
Quick Reply: Exhaust Manifold Shield...How do I remove it ?
