Engine and shift cable on 94 ex accord
Old 08-18-2007, 12:50 PM
toddyfresh's Avatar
Default Engine and shift cable on 94 ex accord
I have a 1994 Accord EX and I am replacing the motor in it. I was wondering if the ex and dx differ. When I called around a couple places they said they did but I was wondering what the difference was.
Also I was taking the motor out of my Accord and I screwed up the shifter cable on it. I looked on the manual and it says about removing the exhaust pipe and heat shield. I was wondering if all that had to be done or if I could just crawl under there and take a clamp off or something. Thanks guys.
Old 08-18-2007, 03:28 PM
sir_nasty's Avatar
Default RE: Engine and shift cable on 94 ex accord
EX and DX are different motors. Both are the 2.2L I4, but the EX is a V-tec SOHC, and DX is just a SOHC. As for the shifter cable I am not certain but you may very well have to lower the exhaust a bit to get to it.... what did you screw up on it?
Old 08-18-2007, 03:51 PM
toddyfresh's Avatar
I thought I had everything disconnected on it stretched the cable and frayed it. A local j/y has one but i was just checkin on how to get it out if i could go to like a u pull it and save a couple bucks or get it already removed
pr1madona
02-23-2014 11:26 AM
strikeaccord13
04-08-2011 02:56 PM
brent93
01-18-2010 03:50 PM
wlhei
08-23-2006 01:14 PM
Hondamatic
04-29-2006 08:20 PM
Quick Reply: Engine and shift cable on 94 ex accord
