fly wheel spinning, crank shaft not.
RE: fly wheel spinning, crank shaft not.
that is why i stress the issue on inputting the year and model ( at, 5sp, 4dr, i4, v6) in the signature that way we can give members the proper reply without having to waste space asking question that can be answered if they input all the info in the signature
going back to your question you never did specify if car is AT or 5SP..
AT tranny does not have a flywheel. it has a torque convertor with a gear tooth on it and a flex plate , the flex plate bolts onto the the crankshaft with 6 bolts and bolts also onto the torque convertor with 8 , 10mm bolts
5SP tranny have just the flywheel, which bolts on the crankshaft , then the clutch and plate bolt onto the flywheel , the flywheel has tooth gear as well..
so like i said earlier ,, if it is an AT tranny i would look at the flex plate center piece broken off , i have seen a lot of those ,, never seen a flywheel brake except worn teeth on the gear or a broken tooth or 2 ..
so first thing you should do ??? Input all the info we need in your signature so we can answer your question properly and faster
How's this?
(copied from the other thread...)
Flywheel(#3) & clutch(#4&5) from manual tranny in the bottom half of the picture.
Your automatic is like the top picture. Number 7 is the flex plate, but Honda apparently calls it a drive plate. The gear teeth for the starter are actually on the torque converter itself (#6).
In both cases the engine is off the left of the picture. Imagine you're standing at the right-side door...
guys im going to have the car on a hoist when droping out the tranny, do i need to support the engine or would there still be enough engine mounts to hold, also i cannot leave the car on the hoist can i just put back the front wheels on the hub and roll it out the shop, my co worker told me leave the drive shafts in and and let them flop around other wise i can damage my wheel barings without them on.
no need to support the engine ,but make sure to leave in a bolt for the rear mount that goes through the block , just stick it in, put a nut loosely on the other sode so it does not come out i have done it many many times , also take the axles totally out, your bearings will NOT be damaged at all , i have done that a bunch of times ,, but before you put the wheels back on and roll it out you have to reconnect the lower ball joint into the control arm, with the 17 mm castle nut,, then you can put the wheels on and roll it out ,,
#17
ORIGINAL: deserthonda
no need to support the engine...
...also take the axles totally out, your bearings will NOT be damaged at all...
The engine hangs OK without the mount at the end of the tranny?
Without a preload on the bearing, it's nowhere near as strong as normal. But I guess you won't be taking corners very fast while the tranny is out...
#18
ORIGINAL: JimBlake
And as for the bearing it will not damage it at all,, all you are doing is to push the car out of the bay ,, no big deal
#19
took the tranny out today just like we all thought a broken flex plate, also 1 of the dowell pins are missing could this b the reason it broke? honda wants $100 aftermarket $85 im going to go with after market should be the same.
