Sponsored by:
Sponsored by:
Front Windows will not shut flush!
Old 06-14-2005, 07:14 PM
Dewbers
Default Front Windows will not shut flush!
when I open and attempt to close the front electric windows on my 96' Accord they keep dropping and will not close properly, any thoughts or suggestions?
Thanks
Old 06-14-2005, 10:00 PM
Default RE: Front Windows will not shut flush!
the door/window construction is pretty simple - the motor that is fixed on a regulator that holds the window.
my best guess would be that the regulator is damaged or jammed in some way. But you have to open it and see to be sure.
Old 06-16-2005, 11:00 AM
the regulator is prob. bad. just take the panel off and peel the plastic back and check it out. should be to hard.
Old 06-16-2005, 10:18 PM
ORIGINAL: accordlowered04
I hope you ment to say should NOT be too hard
Old 12-01-2005, 01:12 AM
procrael
99 Accord Front Window - Similar Problem
My front power window suddenly developed a problem today. As I was trying to open the window it went down slower than usual and there is some sort of grinding noise and when I tried to get it back up again it would not go all the way up. I took the door panel off and I was able to physically move/pivot the window left and right by a few degrees and help it to get back up. So there seems to be some resistance somewhere - how do I know if it is the motor or if it is the regulator assembly that is bad? Can you see anything visually if the regulator gone bad?
Thanks
Old 12-04-2005, 06:45 PM
deserthonda's Avatar
you need window regulators,, there is a little white plastic piece that brakes and cable cannot close windows all the way they stay about 1/4 to 1 inch from the top ....i cannot remember exactly on 96 ..but i believe that window regulator comes with the motor on that particular year and model
Itzlogiccsaccord
03-16-2013 10:02 PM
Honda Man For Life
04-09-2012 09:38 AM
dtcaccord
06-04-2008 09:54 PM
th22ek9
09-13-2006 11:11 PM
th22ek9
09-08-2006 09:07 PM
Quick Reply: Front Windows will not shut flush!
