door panel removal, handle and lock is holding it in
Old 06-22-2005, 06:09 PM
ryan ortego
Default door panel removal, handle and lock is holding it in
Hello,
i need help gettin my door panel off. 1990 honda accord 4 door. I have all screws off. The bottom half is off. The only thing holding the door on is the handle and lock piece. I have the one screw off, there is something inside the door that is holding it on. What is it and how do i get it off. Thanks so much
Ryan
Old 06-24-2005, 08:31 PM
Default RE: door panel removal, handle and lock is holding it in
on the door handle there a clip kinda thing that attaches to the aluminum piece that opens ur door... u need to unclip that to take the handle off....
is it manual or auto?
Old 12-04-2005, 02:24 PM
First of all, if you haven't done this. You need to push the entire lock unit forward to unclip from the door. Once thats accomplished there is a plastic clip that connects the rod that operates the door lock to the handle. you need to unclip that but be carefull not to break it. Thas sometimes happen when they get old. Good luck
Old 12-04-2005, 04:10 PM
beets442
overlord is right , the clip will break if your not carefull-alittle light oil an a small screw driver ,lightly push clip off off rod
moparmusclecars
07-16-2013 10:10 PM
Doublel
03-11-2013 07:57 AM
nismogrendel
02-07-2013 07:03 PM
JPodAccord
05-26-2012 05:10 PM
Motman Idaho
03-22-2012 10:20 PM
Quick Reply: door panel removal, handle and lock is holding it in
