Fuel filter location on a 97 Accord - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 09-16-2005, 12:39 PM
mojorison_75
Default Fuel filter location on a 97 Accord
Where is the fuel filter located on a 1997 Accord SE? Is it in or outside the tank?
Old 12-04-2005, 03:00 PM
Default RE: Fuel filter location on a 97 Accord
The filter is on the drivers side of the car close to the fire wall. Just follow the hose that goes down from the fuel rail.
Old 12-04-2005, 07:40 PM
deserthonda's Avatar
under the brake master cylinder ...like ovr said follow the top line /// the trick is to get a 14mm crow foot, a long extension and a rachet ..raise car, loosen the bottom line. lower car, remove the 17mm banjo bolt at the top, undo the lower line from the top u might want to put a pan under filter some fuild will spill. remove the 10mm bolt that attaches the fuel filter bracket and remove the filter/bracket assembly ..it is a bit of a tight fit but it will come out ,, once out remove the 10mm bolt and replace the filter ...............once u go back in,, firtst thing u do is start the bottom line from the top finger loose then put top all together and last thing do not forget to tighten bottom line
Reply
Thread Thread Starter Forum Replies Last Post
1986 Honda Accord Fuel Filter Location ifixm General Tech Help 3 03-26-2015 07:01 PM
98 honda accord fuel pump and fuel filter rockhoundrob General Tech Help 7 04-11-2014 12:41 PM
2000 accord EX V6 fuel filter location?? byebye2u General Tech Help 3 12-21-2012 05:47 PM
Fuel filter location rustyblueyez General Tech Help 2 07-25-2010 06:16 PM
99' Accord EX 2.3L Fuel Filter Location...In-line, Tank or Both gary General Tech Help 2 05-24-2006 01:10 AM
Tags
1997, 97, 97accord, accord, change, filter, fuel, gas, honda, install, located, os, pump, rail, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
