Fuel Pressure Regulator - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 08-30-2007, 01:11 PM
martinh
Default Fuel Pressure Regulator
Does anyone know where the fuel pressure regulator is located, and where I might buy one?
2004 accord v-6.
Old 08-30-2007, 04:56 PM
Default RE: Fuel Pressure Regulator
I may be crazy but I was under the assumption that the fuel pump itself controls the pressure. What brings you to looking for one?
Old 08-30-2007, 08:13 PM
martinh
The dealer said that was the problem( hard start). They want 289.00 which I think is dung. I called the parts department and they didn't know what I was talking about. Any Ideas?
Old 08-30-2007, 08:53 PM
deserthonda's Avatar
it is located in the fuel pump,, inside the tank, remove the fuel pump, then you can remove the regulator ,,the only place i know where to get 1 is the dealer
how many miles in your car ?? i have to assume over 36k ,,thus out of warranty ??
there is a bulletin on this ( 03-079 may 2006 ) .. i feel that honda should do it free of charge ..I would contact honda of america and request a free replacement ,,
Old 08-31-2007, 10:09 AM
martinh
71,000 miles. Doesn't sound like a job I want to do. I'll check the tsb. Thanks.MH
Old 08-31-2007, 10:15 AM
martinh
71,000 miles. I'll check the TSB, as this sounds like more than I want to get into myself. Thanks.
Old 08-31-2007, 10:37 AM
martinh
Can't seem to find the TSB in this forum.
Old 08-31-2007, 10:46 AM
Old 08-31-2007, 12:35 PM
Quote:
ORIGINAL: martinh
that's because you are not looking in the right place or not looking hard enough
http://www.hondaaccordforum.com/Grea...m_41104/tm.htm
follow the directions,,
user input user
password input password
go to the bottom, auto repair . click on it, input the model and year , go to service bulletin , fuel, and it is right there..2nd from the bottom
Reply
Thread Thread Starter Forum Replies Last Post
98 Accord V6 Fuel Pressure Regulator location? djames General Tech Help 1 07-21-2013 10:00 PM
Fuel Pressure Regulator RobinsonRicer General Tech Help 6 07-30-2012 03:21 PM
Fuel Pressure Regulator ? djalmab General Tech Help 9 12-17-2011 09:08 PM
1998 Honda Accord EX - Replacing The fuel pressure regulator techjohnny General Tech Help 18 02-20-2011 09:22 PM
fuel pressure regulator jamrock General Tech Help 4 11-14-2008 02:17 PM
Tags
2000, 2004, 95, accord, check, diy, fuel, honda, location, pressue, pressure, regulator, replacement, tsb, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
