Sponsored by:
Sponsored by:
Fuel Pressure Regulator
Old 08-30-2007, 01:11 PM
martinh
Default Fuel Pressure Regulator
Does anyone know where the fuel pressure regulator is located, and where I might buy one?
2004 accord v-6.
Old 08-30-2007, 04:56 PM
sir_nasty's Avatar
Default RE: Fuel Pressure Regulator
I may be crazy but I was under the assumption that the fuel pump itself controls the pressure. What brings you to looking for one?
Old 08-30-2007, 08:13 PM
martinh
The dealer said that was the problem( hard start). They want 289.00 which I think is dung. I called the parts department and they didn't know what I was talking about. Any Ideas?
Old 08-30-2007, 08:53 PM
deserthonda's Avatar
it is located in the fuel pump,, inside the tank, remove the fuel pump, then you can remove the regulator ,,the only place i know where to get 1 is the dealer
how many miles in your car ?? i have to assume over 36k ,,thus out of warranty ??
there is a bulletin on this ( 03-079 may 2006 ) .. i feel that honda should do it free of charge ..I would contact honda of america and request a free replacement ,,
Old 08-31-2007, 10:09 AM
martinh
71,000 miles. Doesn't sound like a job I want to do. I'll check the tsb. Thanks.MH
Old 08-31-2007, 10:15 AM
martinh
71,000 miles. I'll check the TSB, as this sounds like more than I want to get into myself. Thanks.
Old 08-31-2007, 10:37 AM
martinh
Can't seem to find the TSB in this forum.
Old 08-31-2007, 10:46 AM
sir_nasty's Avatar
Old 08-31-2007, 12:35 PM
ORIGINAL: martinh
that's because you are not looking in the right place or not looking hard enough
https://www.hondaaccordforum.com/Gre...m_41104/tm.htm
follow the directions,,
user input user
password input password
go to the bottom, auto repair . click on it, input the model and year , go to service bulletin , fuel, and it is right there..2nd from the bottom
djalmab
06-13-2018 02:38 AM
djames
07-21-2013 10:00 PM
RobinsonRicer
07-30-2012 03:21 PM
techjohnny
02-20-2011 09:22 PM
jamrock
11-14-2008 02:17 PM
Quick Reply: Fuel Pressure Regulator
