fuel pressure regulator
jus found out i got a code 43 did some searching around and found out that the fuel pressure regulator was bad it as letting fuel go back through the vacuum line. my question is does anyone know where i an find a thread on how to replace it and if that would cause an irratic idle problem
RE: fuel pressure regulator
Can you define 'irratic'?
Next time you open the hood look for the little sticker that shows WHAT YEAR the Accord is.
Usually there are 2-10mm bolts holding the F.P.R. on the rail.
yea put your year and model in your signature so we now what your talkin about
as for problems with erratic idle u should be able to find many threads about that, search and then post back with any questions, i had problems with erratic idle myself for a while but did end up fixin it.
Check coolant levels be sure the block is burped thru the 12mm bleed screw at the T-stat housing.
If that is all well and good, adjust the FITV. It lays sideways under the throttle body intake opening.
2 phillips screws hold the cap on, then inside is a nylon 'split' screw with a brass cone sticking thru the center. Turn the screw in a couple turns, you should hear no air bypassing in there when the engine warms up.
techjohnny
02-20-2011 09:22 PM
