Sponsored by:
Sponsored by:
Fuse problem with tail lights
Old 05-25-2011, 08:10 PM
charless21's Avatar
Default 96 accord Fuse problem with tail lights
I have a 96 accord and my fuse for the tail lights continues to blow when I turn on the lights. My signal and brake lights work fine. Please help, this is giving me a headache thanks. fuse is 15
Last edited by charless21; 05-25-2011 at 08:24 PM. Reason: forgot to post year in title
Old 05-26-2011, 09:32 AM
crispin's Avatar
I had this problem when I bought this car.
It is very hard (read impossible) to figure out.
A few other guys have also had this problem.
There are a few good intending, smart fellows on this board which will direct you to spend hours and hours tracing circuits to find and correct the problem.
I feel I have the best way to fix it.
It is simple, will take you 10 mins to complete.
Here is the thread I started on this problem.
I also had no dash lights sounds like you just have no taillights.
You will need to run just 1 new wire to correct your problem.
https://www.hondaaccordforum.com/for...ocation-35068/
Old 05-26-2011, 10:26 AM
crispin's Avatar
Here is the breakdown
Run a wire from your fusebox in the drivers footwell to the trunk.
cut the red wire with a black stripe you can find that wire behind the taillight bulb access panel on the drivers side.
Connect the wire you ran to that red/black wire
presto - working taillights.
Cost = very little.
If you have a 96 then you also have the taillights on the trunk lid to power up as well.
The last page of the link I gave you explains how I did that.
Old 05-26-2011, 09:17 PM
charless21's Avatar
My dash lights are also out.
Old 05-27-2011, 04:02 PM
Check the bulbs, they are a dual filament bulb....so if the running light filament is gounding in one of them...bam, fuse goes. Cheap and easy check.
Old 05-30-2011, 07:06 PM
charless21's Avatar
thanks poorman212I'll give that a try.
Old 07-27-2011, 11:27 AM
crispin's Avatar
I had this same problem...This is how I fixed it
Uberpippi
02-01-2013 10:09 PM
alyssapie
08-13-2012 10:58 PM
myfirstisanaccord
04-24-2011 08:25 PM
uchimata
12-16-2010 11:55 AM
HongGildong
11-11-2006 01:49 PM
Quick Reply: Fuse problem with tail lights
