RPM's Drop After Engine Start
Old 07-05-2006, 04:29 PM
bedwards97
Default RPM's Drop After Engine Start
'01 EX, V6....Engine starts fine, but right after ignition the rpm's drop nearly to the point of engine dying, then slowly recover to normal idle. A/C is not on at this time.
Any ideas??
Old 07-05-2006, 05:14 PM
YeuEmMaiMai's Avatar
Default RE: RPM's Drop After Engine Start
clean your ICV and see if that fixes the problem. Also clean the TPS sensor along with the intake
Old 07-05-2006, 06:53 PM
sir_nasty's Avatar
okay so I've had WAY to much caffiene today.... what do you mean by ICV?
sir_nasty's Avatar
are you talking Idle Control Valve? do you know where that's located on a 01?
Old 07-05-2006, 07:02 PM
well since my car is in the shop I cannot look but I can tell you tomorrow when I get it back
Old 07-05-2006, 08:30 PM
sir_nasty's Avatar
I can almost hear the underlying tone of mass amounts of profanity mixed in with the words "shop" and "transmission" in that post *LOL*
Old 07-05-2006, 10:46 PM
Chiovnidca's Avatar
The idle air control valve (IAC) is bolted to the bottom of the throttle body.
Mason James Mattias Roberts
07-26-2015 10:33 PM
dta4316
05-20-2014 12:15 PM
blklavender
04-04-2011 01:32 PM
manumatic6
08-08-2010 06:41 PM
JohnL
11-23-2007 05:20 PM
Quick Reply: RPM's Drop After Engine Start
