Getting a new master key
Old 06-14-2008, 05:45 PM
SJCarlson22
Default Getting a new master key
Hi,
I just recently got a fantastic 97 Accord EX. However, unfortunately the keys I have are a door key and an ignition key. From the owner's manual, I learned that the ignition key is actually the vallet key, and I am missing the master key. This is annoying to have separate keys, and I can only open the trunk from the inside, since the door key I have will not work on the trunk. Is there a way for me to get a replacement for this master key, and if so, about how much would this cost?
Thanks!
Old 06-14-2008, 06:06 PM
Default RE: Getting a new master key
A master key is no problem on a 1997 Accord....'98 is a different story. Anyway, go to your local Honda dealer and they can cut a new master key by looking up the VIN on your car. This is providing that thekey combination has not been changed (ignition switch and door locks changed). A new master key from a Honda dealer for a '97 or olderHonda should not cost over $10 maximum andmost likely around $7.
Hope this helps.
EdBrian
www.accuratecars.com
Old 06-15-2008, 03:07 AM
SJCarlson22
Okay, I will try this. Thanks for your help, Ed!
Old 06-16-2008, 07:40 AM
Sothe door key doesnt fit the ignition and the ignition key doesnt fit the door??Theyre supposed to be the same. So the lock cylinders HAVE been changed around.
Old 01-30-2011, 12:06 PM
Hope this helps.
EdBrian
Thanks![/quote]
That was so helpful. I was able to get a new master key from the Honda dealer for 9.23 plus tax. I bought two of them for 20.00. All you need is your license and your registration to prove ownership and VIN no. Thanks so much
duckytim
01-05-2016 10:59 AM
csh217
06-17-2014 05:53 PM
brassbanana
02-10-2014 02:44 PM
corlyf
09-12-2012 11:30 PM
tiger94
09-04-2006 04:40 PM
Quick Reply: Getting a new master key
