Sponsored by:
Sponsored by:
How to test AC blower resistor??
Old 06-16-2008, 08:55 PM
04SatinAccordTX
Default How to test AC blower resistor??
Posted another thread and everytime I click on the thread it gives me the following screen.....
Bad Request
Your browser sent a request that this server could not understand
Anyway, is there a way to test the AC blower resistor before I go buy a new one for $50. Then find out something else was the real problem.
Old 06-16-2008, 10:28 PM
Default RE: How to test AC blower resistor??
this site is acting goofy. What year accord? What are the symptoms of your problem?
Old 06-16-2008, 10:46 PM
I just read your other post. I will assume that you have a 7th gen accord.
If the blower motor is not running at all, the resistor is not the likely culprit. A bad resistor would cause the fan not to run at certain speeds.
Check the fuses. There is one in the engine bay box, and a fuse under the driver's dashboard. There should be some kind of label on the covers of the fuse box. There is also a relay in the engine bay box.
Old 06-16-2008, 10:53 PM
I just found an owners manual for an 04 accord. http://www.analogstereo.com/honda_ac...ers_manual.htm
Fuse #21 in under hood fuse box. Fuse #4 (not sure if this is the right fuse) under driver's dash.
Old 07-08-2008, 10:25 PM
jvv1964
Default RE: location of the AC relay??
where can i find the a/c relay ...going nuts here......
Old 07-09-2008, 12:07 AM
You should start a new post. Include your year and model accord.
Also include which A/C relay do you need to find, the compressor or the a/c condenser fan.
2Hondas
06-10-2012 09:41 AM
Honda Man For Life
04-09-2012 09:38 AM
bglovept
11-08-2010 02:37 PM
Nughuffer
12-10-2009 09:51 PM
Nughuffer
DIY Answers.
12-10-2009 09:51 PM
Quick Reply: How to test AC blower resistor??
