Sponsored by:
Sponsored by:
95 accord ex no lock up after rebuild
Old 02-17-2011, 10:27 PM
motleyman's Avatar
Default 95 accord ex no lock up after rebuild
i rebuild transmissions for a living,recently rebuilt the trans in my 95 accord ex,it isn't goin into lockup,the only thing i found wrong with the trans is some frictions had been burnt up due to a trans leak,the abs light is on also,the abs don't seem to b working,could these be related,has anybody had similar situations,any help will be appreciated
Old 02-17-2011, 10:34 PM
I would check for engine, transmission, and ABS computer codes. You just have to follow the instructions in the DIY section on how to get CEL codes.
The check engine light flashs are the engine computer codes.
The D4 light flashes are transmission computer flashes, just like the CEL flashes.
The ABS light will give you ABS codes. This one is a bit different than the other two where the ABS will flash main code, pause for a second, then a sub-code. The ABS will pause for 5 seconds between codes.
Let us know what code(s) were flashed and by which light.
Old 02-18-2011, 07:00 PM
I'm sure you checked the lock up solenoid? Might pull it to be sure the screen is clear and also check that the actual soleniods are good-open and close.
Old 02-18-2011, 07:18 PM
motleyman's Avatar
yes i have checked the solenoid,clean and operating
Old 02-18-2011, 07:40 PM
Did you find any error codes?
Old 02-19-2011, 12:45 PM
motleyman's Avatar
the d4 light is burnt out,guess i need to change tht 1st right
Old 02-19-2011, 06:50 PM
Yeah, it's OBD-1 so the only way to get error codes is the flashing D4 (& flashing CEL).
Old 02-21-2011, 10:32 PM
motleyman's Avatar
ok,got the d4 light changed,checked for codes,got no codes from anything,what now
Old 02-21-2011, 11:32 PM
There are only a couple of things that I can think of. Try measuring the resistance between the proper pin of each solenoid at the TCU connector and body ground to see if it is the same as at the solenoid connector.
You can backprobe each solenoid and hook a test light up to ground, so you can see if there is voltage being sent from the TCU on each solenoid when driving. You would have to run the wire under the windshield to see the light.
Other than that, I am at the limit of what I can suggest.
You can post the ABS code, but I highly doubt that the ABS light has anything to do with the lockup problem. It is worth a shot if the ABS is an easy fix.
Old 02-22-2011, 06:47 PM
Ok and a reach, the throttle control cable is properly adjusted?
EDIT: Found this as well. Codes or symptoms of 3, 6, 11 with no codes -all to do with lock up or should I say lack of....
3=TP sensor
6=A/T position switch
11= Coil wire
Above is high level descriptions, the manual has more detail
Attached Thumbnails 95 accord ex no lock up after rebuild-5th-gen-lock-up.jpg
Quick Reply: 95 accord ex no lock up after rebuild
