Sponsored by:
Sponsored by:
Honda "Limp mode"
Old 04-05-2012, 02:27 PM
argarcia86's Avatar
Default Honda "Limp mode"
My car right now is driving in limp mode cause I still havent replaced the crank position sensor, just curious about the limp mode.
How does limp mode make the car run, besides limiting going over 3000 rpm's.
Does it burn more gas? cause I feel like ill fill up the tank and it will be gone super fast.
I also have a leaking water pump, will this make the car lose power if the water pump is leaking?
Old 04-05-2012, 02:35 PM
crispin's Avatar
It runs rich to help protect the motor.
You should fix it asap
Old 04-05-2012, 10:31 PM
argarcia86's Avatar
yea trying to save up a little money to get it fixed, I dont think i can handle messing with the timing belt and all that.. even though I want to try, its my only transportation..
Old 04-05-2012, 10:42 PM
crispin's Avatar
you will wish you did when that water pump seizes up, snapping your timing belt, and pushing your pistons into your valves.
I would not drive the car any further until it is repaired.
imsohungover
04-08-2017 08:18 PM
matthewtorres2323
03-18-2015 12:49 AM
hondavtec94
02-27-2014 12:54 PM
thumper44
09-22-2010 05:02 PM
ronjr8102
08-31-2010 07:05 PM
Quick Reply: Honda "Limp mode"
